Unable to ping host from router.
Answered Question
Feb 11th, 2007
I set up my cisco 2514 router today and connected a pc to the Ethernet (AUI) port. I am able to ping my router from this computer however I am not able to ping to the computer from the router. What is the problem?
Ethernet1 is up, ling protodol is up.
I have tried static and DHCP ip's and it does not seem to work.
Correct Answer by albert.remo about 10 years 2 months ago
Hi!
Good Day!
What operating system are you using? We have experienced several instances that when using WindowsXP, ICMP echo is not allowed by the internal firewall of the OS. Try temporarily disabling the firewall or go to Windows Firewall/advance setting and allow ICMP echo.
Hope this helps,
Albert
Overall Rating: 5 (1 ratings)
Correct Answer
albert.remo Sun, 02/11/2007 - 19:56
  • Silver, 250 points or more
Hi!
Good Day!
Hope this helps,
Albert
spremkumar Mon, 02/12/2007 - 00:15
  • Red, 2250 points or more
If you firewall is disabled in your pc then do post your config of your router and also the output of show ip arp taken from your router..
regds
