Home Lab setup: Recommendations for router + PIX
Feb 11th, 2007
Hello everyone.
Wanted to get some suggestions for a home lab setup as I am preparing for my CCNA and CCDA. Future learning will probably include PIX/ASA as well.
Here is my question.
I just bought a PIX 501 off ebay for a good price. I am going to use this at home to learn and practice on.
I wanted to get some recommendations on a router to look for to hook up for my home connection as well.
I am a hands on type of guy, so I figure if I can setup a mini-cisco network at home (have to get some approval from the wife :) hehe ), that would go to great lengths in getting hands on experience. I know it is not the same as being in a larger environment, but still helps. Plus it is fun.
With that, what are some recommended routers to take a look at? Models?
I have a cable modem connection with a 12mb download and 1mb upload.
Just wanted to get started here. Once I get this in place, we shall see what happens next.
Thanks everyone.
Jason
daviddtran Fri, 02/16/2007 - 05:59
instead of purchasing a pix501, you can
purchase an ISA flash card for less than the
price of a pix501 and build yourself a "franken"
pix that will run exactly the same code as
pix501, 506E or 520. Even better, you can
do 802.1Q on the franken pix and actually have
DMZ interfaces on the franken pix which you do
not have on Pix501.
For IDS, you can get a recovery CD from Cisco
and build yourself a franken IDS version 4.1 and learn more about IDS.
For Cisco ACS, download the 90 days version
and install it on your PC so you can learn
how tacacs and radius works.
Once you learned how these things work, go
to an interview and the employers will offer
you a job on the spot.
My home lab has both franken pix and franken
IDS and that's how it help me prepared for the
security lab.
thecoffeeguy Fri, 02/16/2007 - 08:18
Thanks!
Just a couple of questions.
Where can I purchase a ISA flash card? I saw one some place, a 16mb card that was $700!
For IDS, where can I get a recovery CD?
ACS, is that downloadable from Cisco's website?
Thanks.
daviddtran Fri, 02/16/2007 - 09:44
you can find ISA card via auction. $700 is quite expensive. $300 sound reasonable. To build a franken Pix 520, you need ISA flash
card, Intel EtherExpress Fast Ethernet cards
i825759, 440BX-SE-2, floppy drive, 128MB PC-100 RAM. You then have a franken Pix capable of running version 6.3(5). Keep in mind that the 440BX-SE-2 can only have 4 PCI slots so you can only have a maximum of 4 physical NICs but you can have a lot of logical interfaces due to 802.1Q capabilities available in version 6.3(5).
As far as the IDS goes, you can look online
for the 4.1 recovery CD. Again, to have the
Franken IDS to work properly, you need to have
the same NICs for the Franken IDS as the
franken Pix.
ACS version 4.1 is downloadable from cisco
website if you have a valid CCO account.
Good luck to you.
CCIE Security
