lan-2-lan vpn via inside interface
Feb 11th, 2007
Is it possible to have a lan-2-lan VPN via the inside interface - PIX 525 running 6.3.5
Reason is we have 2 primary sites and need to have some traffic between the DMZ's. If possible it would allow traffic between the DMZ's via our internal network.
thanks
Peter
kaachary Wed, 02/14/2007 - 10:01
Hi..
Sure you can have VPN via inside interface. The configuration would be very similar to the "outside" vpn . Few changes in crypto would be like :
isakmp enable inside
cry map interface inside
and few changes in nat statements :
nat (dmz) 0 access-list X
HTH,
-Kanishka
peter2904 Thu, 02/15/2007 - 18:38
Hi Kanishka
Thanks for the info. Think I may have the NAT wrong as the VPN did not try to establish. But then does 'NAT 0' work from a DMZ to inside interface? Thought NAT 0 was only for traffic going the other way?
kaachary Fri, 02/16/2007 - 05:28
Nat 0 works bidirectionally. So, if you have
It would work for traffic going to inside as well as for traffic going to outside interface. So, the VPN traffic entering the FW from DMZ and going to inside n/w needs to have a Nat (dmz) 0 or a static .
HTH,
-Kanishka
