Clustering Over the IP WAN
Feb 11th, 2007
Hi All,
I am seeking clarification on the IP WAN bandwidth required given the following scenario;
Publisher and Subscriber located in Data Centre and 4 remote Subscribers clustered over the IP WAN.
When provisioning bandwidth for IP WAN to accommodate ICCS, database and other inter-server traffic would it be correct to assume the calculation is as follows?
Data Centre - 6.176 Mbps
Remote Site 1 - 1.544 Mbps
Remote Site 2 - 1.544 Mbps
Remote Site 3 - 1.544 Mbps
Remote Site 4 - 1.544 Mbps
Thks.
jlzfeeney Sat, 02/17/2007 - 17:15
As long as QOS is designed for CS3 and RTT for ICCS traffic is maintained at 40ms (per SRND), it should be fine. My question is the distance from the Data Center to the remotes? Are you utilizing a Teir 1 provider. What other apps are on the WAN?
