VPN Tunnel have many error packet.
Feb 11th, 2007
VPN Tunnel have many error packet. I would like to know, what is the root cause of error packet on VPN tunnel.
Following show an error packet on VPN tunnel.
local ident (addr/mask/prot/port): (172.17.100.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (192.168.120.0/255.255.255.0/0/0)
current_peer: 59.37.15.226:500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 1778, #pkts encrypt: 1778, #pkts digest 1778
#pkts decaps: 1145, #pkts decrypt: 1456, #pkts verify 1456
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0
#send errors 13, #recv errors 311
local crypto endpt.: 58.137.23.66, remote crypto endpt.: 59.37.15.226
path mtu 1500, ipsec overhead 56, media mtu 1500
current outbound spi: bb08ca7a
inbound esp sas:
spi: 0x4d169cb5(1293327541)
transform: esp-3des esp-sha-hmac ,
in use settings ={Tunnel, }
slot: 0, conn id: 5, crypto map: IntertekSHmap
sa timing: remaining key lifetime (k/sec): (4607874/24159)
IV size: 8 bytes
replay detection support: Y
pradeepde Fri, 02/16/2007 - 07:23
I think this may due to the packed which is not encapuslated from the remote end or it could be a problem with your tunnel group configuration. Check these error is coming while iniating the tunnel and in between the data is transfering.
