reg-ASA5520 vpn
Feb 11th, 2007
Dear sir,
in my network iamhaving pix515e now iam changing the pix to asa5520.my pix 515e is already configured that same config iam changing to asa5520 in vpn group iam getting one messiage is given below
the 'vpngroup' command has been deprecated, and will be converted to th
e corresponding tunnel-group and group-policy syntax
it is any error and iam not able to connect my vpn.
plz anybody help me out in this
Thanks &regards
D.srinivas
shomar Fri, 02/16/2007 - 13:06
Hi D,
as mentioned, the vpngroup no longer exists in version 7.x, however, if you can list your old configuration, maybe I can help you what shod the new configuration be :) and you can compare that to your new configs.
Kindest regards,
Shadi`
