G.703 Card Installation
Answered Question
Feb 11th, 2007
I have a WAN link between our two sites is coming up that will terminate on VWIC-2MFT-G703 card on both sides. I have 2811 on both sides. When I installed the G703 card, it showed up as E1 controller. For its initialization, I issued the following commands under E1 controller configuration:
channel-group 0 unframed
linecode hdb3
clock source internal
Doing so created a serial interface on the router. I gave the IP to this interface. Do I need to do anything else before terminating the circuit?? Thank You in advance.
Sheeraz
Correct Answer by spremkumar about 9 years 7 months ago
This minimal config is enough to get started..
Once you have ur line terminated you can check the status of the line including errors/reliability etc.,
regds
Overall Rating: 5 (1 ratings)
Correct Answer
spremkumar Mon, 02/12/2007 - 02:04
regds
