Range of port in static NAT ??
Feb 12th, 2007
Is there any way I can set range of port in static NAT
I want open UDP port 5000-6006 to one IP inside.
exp:
This command open only tcp 1720
'ip nat inside source static tcp 10.80.150.10 1720 80.89.47.102 1720 extendable'
Thanks for your help.
Jon Marshall Mon, 02/12/2007 - 04:50
In the search Netpro box type "nat port range".
Third entry down should answer your question.
Sorry i would link it but i can't seem to do it.
Jon
