rspan
Feb 12th, 2007
hi all;
i want to ask if 4006 switch support rspan (remote span ) or not.
For your information its contain sup III and IOS software
Amit Singh Mon, 02/12/2007 - 01:38
Yes, it should support RSPAN. What is the IOS you are running. Please paste the show version from the switch.
-amit singh
smothuku Mon, 02/12/2007 - 01:55
Hi ,
It supports RSPAN.If possible can you paste the CatOS and IOS which you are using in 4006 switch.
satish
jawwalit Mon, 02/12/2007 - 06:22
thanks
please see the following IOS version
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-IS-M), Version 12.1(8a)EW1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 20-Feb-02 18:02 by eaarmas
Image text-base: 0x00000000, data-base: 0x00AA30DC
ROM: 12.1(12r)EW
cs-01-lan uptime is 3 days, 14 hours, 40 minutes
System returned to ROM by reload
System image file is "bootflash:cat4000-is-mz.121-8a.EW1.bin"
cisco WS-C4006 (MPC8245) processor (revision 7) with 262144K bytes of memory.
Processor board ID FOX0708S04A
Last reset from Reload
152 Gigabit Ethernet/IEEE 802.3 interface(s)
467K bytes of non-volatile configuration memory.
jawwalit Thu, 02/15/2007 - 02:00
can you please give me the version of iOS that support Rspan, and how i check in my switch that it support rspan
thanks
Jon Marshall Thu, 02/15/2007 - 02:29
I don't think your IOS supports rspan. From the config doc for your IOS they only talk about span:-
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_guide_chapter09186a00800f0e28.html
It looks like you need 12.1(20)EW as a minimum. The best thing to do is check on software advisor which is a Cisco tool
http://www.cisco.com/en/US/support/tsd_most_requested_tools.html
Jon
jawwalit Thu, 02/15/2007 - 03:38
thanks,
i checked it on the software advisor bu it give the following nessege:
Remote SPAN (RSPAN) Support for source and destination SPAN ports located on other compatible switches
for your knowledge the 4006 consist supIII engine
thanks
