Setup a restriction
Feb 12th, 2007
Hi all, i have a PBX connected to Cisco 2811 through ISDN, what i wanna do is how can i restrict specific phone extensions to call numbers that begin with 99.
Thnx in advance.
Paolo Bevilacqua Mon, 02/12/2007 - 07:47
Are you using CME ?
You can configure either COR (Class Of Restrictions) or PIN/Login. Search for that on CCO.
COR is static, and can be integrated with another technique, special prefixes, for override. PIN/Login requires a per-phone PIN to unlock certain forbidden (permanently or within certain hours) user-definable patters.
