MPLS on Port-Channel
Feb 12th, 2007
Is it possible to configure TE on a Port-Channel ?
I don't see the command mpls traffic-eng tunnels
CSCO-CORE-SPO(config-subif)#mpls ?
accounting Enable MPLS accounting on this interface
bgp MPLS BGP
ip Configure dynamic MPLS forwarding for IP
l2transport Layer 2 packet over MPLS config commands
label Label properties
ldp Configure Label Distribution Protocol (LDP) parameters
mtu Set MPLS Maximum Transmission Unit
netflow Configure Egress Netflow Accounting
CSCO-CORE-SPO(config-subif)#mpls tr
azago Thu, 02/15/2007 - 03:37
s72033-advipservicesk9_wan-mz.122-33.SRA2.bin
aheinz Thu, 02/15/2007 - 06:14
Try:
interface GigabitEthernet1/2
channel-group 1 mode active
interface GigabitEthernet1/3
interface Port-channel 1
switch-port
switch-port access vlan 1507
switch-port mode access
interface vlan 1507
mpls traffic-eng backup-path Tunnel1
mpls ip
Rgds
Andreas
aheinz Thu, 02/15/2007 - 08:09
if you can't change to that config, use 12.2.18.sxf 5 or wait until it is supported in SR.
Rgds
Andreas
