MHSRP + BGP + 3560
Feb 12th, 2007
Hi ,
My customer want do a load balance links between 02 ISPs (different AS), He will use 02 Cat 3560( but, 3560 does not support IBGP). I think use MHSRP(02 groups for load balance) and BGP for the external links. This solution will works ?
Any suggestion ?
TIA
Alexandre
smalkeric Fri, 02/16/2007 - 06:54
You can configure MHSRP to achieve load balancing and to use two or more standby groups as you would normally configure for router.standby 1 preempt, standby 1 ip 171.16.6.100,standby 2 preempt, standby 2 ip 171.16.6.200, standby 2 track serial 0,
standby 2 priority 95.
