DHCP Issues
Feb 12th, 2007
Hi.
Has any one tried to setup DHCP on IOS switches or routers? I had as issue providing DHCP to IP Phones via a L2 switch, found that when the switch is rebooted, all DHCP bindings are gone, phones retrieve new IP addresses and fail ro register with CCM.
Any similar cases?
Cheers.
Paolo Bevilacqua Mon, 02/12/2007 - 12:00
It should work fine. Why the PC are failing to retrieve address? Do you have portfast enabled on the switch, and a separate voice /data vlans ?
