Upgrade from ACS3.3.2 to 3.3.4
Feb 12th, 2007
I have a pair of 3.3.2 windows servers that need to be upgraded to 3.3.4. Is there any issues that I should know about before I do this upgrade. I assume I should do the backup servers first.
Thanks in advance.
Mike
mapones Mon, 02/12/2007 - 08:20
Thanks I have seen the document. When you say do a backup is there a backup out of the ACS software, or do you just mean a full backup of the server?
Mike
Vivek Santuka Tue, 02/13/2007 - 06:54
Backup with ACS means the database backup which can be taken from System Configuration->ACS Backup.
Vivek
mapones Wed, 02/14/2007 - 07:39
Great that is what I thought you meant. I will do that. I just wanted to see if there were any other issues that people have run across. So all my setting "should" be there when I am done if I select "Import Existing Conf". I just want to make sure this goes somewhat smooth.
Mike
Vivek Santuka Wed, 02/14/2007 - 07:52
Mike,
That is right. All settings should be there if you select "Import Exisiting conf." while upgrading.
Vivek
