Database Subsystem does not start
Feb 12th, 2007
Is there any trick to getting the database subsystem to start?
IPCC 4.5 Premium
I have created an ODBC connection to the database and that connection is successful when testing. I have also setup the data source in IPCC to match.
Any thoughts of what I'm missing?
Thanks.
ryan_oconnell Tue, 03/20/2007 - 08:57
Did you get this fixed, I'm using the same versions as you and having the same problem
Gergely Szabo Tue, 03/20/2007 - 09:41
Double check:
- ODBC: System DSN?
- mixed mode (win+sql) auth enabled on sql server you set up the ODBC link to?
- ODBC link uses SQL auth?
- sql user and password information on Subsystems>Database>Datasource entries the same as in the ODBC entry?
