Upgrade from CatOS to IOS on switches
Answered Question
Feb 12th, 2007
Can I upgrade my Catalyst switches from CatOS to IOS? Is there somewhere I can find out?
Mike
Correct Answer by glen.grant about 9 years 7 months ago
It depends on what supervisor you have , it must be at least a Sup II Plus to have ios . If it is only a sup II you cannot change it . If it is a Sup II plus it would have come with IOS . My guess is you have a 4500 chassis with a Sup II in which case you cannot upgrade it . You can do a show mod and post here and we can tell you .
Overall Rating: 5 (3 ratings)
glen.grant Mon, 02/12/2007 - 10:20
Need to know what models you are talking. The only ones upgradeable would be the Cat 6500's , anything else is catos only . There are certain hardware requirements to do so also such as nvram and flash etc .....
burleyman Mon, 02/12/2007 - 13:05
But I have some 4506's that have IOS? Can't I upgrade my other 4500's?
Mike
Correct Answer
glen.grant Mon, 02/12/2007 - 13:25
burleyman Mon, 02/12/2007 - 13:35
That's it!!! I got it now. Thanks I must have over looked that. I have some supII and some supII+.
Mike
