wanting to turn on IP CEF
Feb 12th, 2007
I have a high visability production LAN network for a major corporation. I wnat to turn on IP CEF switching. I don't think this config change will effect / interupt the traffic but I just want to confirm. Thanks.
Overall Rating: 4 (2 ratings)
sundar.palaniappan Mon, 02/12/2007 - 11:06
You had indicated this is a high visibility network and hence, any changes unless you are 100% sure that it won't cause any disruptions you are better off scheduling the changes to be implemented during the maintenance window.
However, AFAIK, enabling CEF switching in the router s/b non impacting unless the code you are running is vulnerable to any severe CEF bugs. With the powerful processing capacity of modern day routers the router s/b able to build the CEF table pretty quickly and no impact s/b felt.
Sundar
PhillipFrueh_2 Mon, 02/12/2007 - 11:13
Thank You Sundar !
I appreciate your prompt response.
the device is a Cat6509 running 12.1.27b IOS
and 12.0.7 XE1 bootloader.
Phil.
