PIX525 Performance Summary
Feb 12th, 2007
I know the PIX525 has a cleartext throughput up to 330 Mbps. What would happen if I go above 330 Mbps ?
Overall Rating: 5 (1 ratings)
a-vazquez Mon, 02/19/2007 - 06:42
Probably, any hardware peripherals are getting affected especially memories, Processor, interface cards etc.
scheikhnajib Thu, 02/22/2007 - 06:23
It will start dropping traffic and I would say that if you are already above 250Mbps you should start feeling a degradation in performance ...
I would recommend an upgrade for your appliance (to 535 or a high performance ASA) if you are over 70% of the stated performance spec's.
Cheers.
S.
abinjola Thu, 02/22/2007 - 10:58
Throughput is the rate at which a firewall sends or receives data . It is therefore is a good measure of the channel capacity of pix
If you increase the throughput more than 300 Mb/sec this means that you actually want to burden the firewall to process and send more data within the same time frame and this would require a higher processor and higher onboard buffer to process and store the data in the queue
Thus if you increase the throughput you would see errors in form of overruns in the sh interface command
hope this helps !
network_team Wed, 02/28/2007 - 08:47
Hi how can i tell what throughput my firewalls are doing at the moment. I am also getting overruns and error, and we believe its beacuse the pix can't handle the trhoughput..... does anyone know were i can find this information
