S O S f?d?rator switch Catalyst 3750G-24TS-S Failure
eh_ham
We are encountering a failure of our federator switch a catalyst 3750G-24TS-S
The startup output on console port is as follow in the attached file
Our network is down (no communication between floors)
Can anybody help us, this is an emergency.
5 Replies 5
smothuku
Level 7
Level 7
Hi ,
It is better open a TAC case with cisco to resolve the issue because traceback is present in logs which can be decoded by TAC engineer for seacrhig for known issues.
satish
I have only guest level acces and cannot use TAC.
I need to know if it is hardware or software problem
please help us
bjw
Level 4
Level 4
A POST ASIC failure is pretty much always a hardware failure. It's the lowest level hardware diag (Power on self test)
The failure is indicated as follow :
POST: PortASIC CAM Subsystem Tests : End, Status Failed
Is the portASIC CAM Subsystem a replaceable component or does the switch have to be replaced.
Thanks for answering.
Hello, I'd like to know how have you fixed this problem. Thanks, Douglas.
