Eth and Serial port with RIP
Feb 12th, 2007
In a situation of two router linked by the serial ports and the fastethernet
port of each router to each of their segment...
Router A Router B
A Segment <------> FastEth FastEth <------> B Segment
Serial <-------> Serial
To be able to send from A to B or vice versa
For Router A
#router rip
#network <IP>
!!!!!Here the <IP> is of which port....
For Router B
#router rip
#network <IP>
Thanks.
Richard Burts Mon, 02/12/2007 - 10:59
Prakash
I do not fully understand your explanation of the topology and perhaps do not fully understand your question. But I believe that the answer you are looking for is that unless you are going to do something in RIP like redistribute connected, then there must be network statements under router rip that include both the interface(s) that rip will advertise over and also network statements that include the segments where end user stations are located that you want to advertise. So in your case it is the IP of both the serial and the etheret ports.
Rick
Desiles1011 Mon, 02/12/2007 - 12:01
Router A Router B
Desiles1011 Mon, 02/12/2007 - 12:03
Router A Router B
A Segment <--> FastEth ----- FastEth <-> B Segment
Serial <---- Serial
