Auto Attendant on Unifed CallManager Express 4.0
Feb 12th, 2007
Does the Unified CallManager Express support Auto Attendant Feature ?
Mohamed
Overall Rating: 5 (1 ratings)
moabdallah Tue, 02/13/2007 - 03:47
Hi Rob,
Thanks for your reply
Without Unity Express, Does the CME support AA ? how many AA ports does it support ?
Mohamed
rob.huffman Tue, 02/13/2007 - 06:06
Hi Mohamed,
Maybe this will help (you do not need CUE for this);
The number of simultaneous calls that Cisco Unified CME B-ACD can handle is limited by the number of PSTN ports, but these ports may not always be in use. For example, you could have three queues with ten slots per queue, but configure only 10 ports instead of 30 because you do not expect the three queues to ever be full at one time.
Cisco Unified CME B-ACD is available for outside calls through voice ports and trunks, for which dial peers must be set up. When you set up a dial peer, you use the service command to associate it with the name of the Cisco Unified CME B-ACD AA service that you want callers to that dial peer to reach.
Note You must configure a dial peer for each incoming DID voice port.
To determine how many ports or trunks you must have for your Cisco Unified CME B-ACD service, consider the following:
Total number of phones across all ephone hunt groups
Total number of slots in the queues across all queues
Total number of PSTN ports feeding into the queues
A maximum of ten call queues and ephone hunt groups can be used with the call-queue script. An AA can use a maximum of three hunt groups from those ten, but an AA can also use fewer than three hunt groups or several AAs can share one or more hunt groups. A shared operator hunt group is not included in that maximum; you can add a shared operator hunt group in addition to the three hunt groups that an AA uses, or it can be part of the three hunt groups. The maximum number of calls that can be in queue for each of the ten possible hunt groups is 30, so a potential of 300 calls can be queued.
The following characteristics summarize Cisco Unified CME B-ACD properties:
A maximum of one call-queue service can be used with any number of AA services.
A maximum of 10 ephone hunt groups can be used with a call-queue service. Each ephone hunt group can have up to 20 extensions.
A maximum of three ephone hunt groups can be used with an AA service; a hunt group that is used as an operator hunt group may be separate or may be one of the three groups.
An ephone hunt group can reserved for a single AA or can be shared among several AAs.
The maximum number of calls that can be queued for an ephone hunt group is 30.
The digit 0 always maps to the hunt group with the highest aa-hunt number in the configuration.
From this excellent doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00805f2305.html#wp1074596
Hope this helps!
Rob
EDIT: Brandon you are too fast for me :)
Take care!
RH
Brandon Buffin Mon, 02/12/2007 - 11:26
Yes it does. You can use B-ACD which is simple auto attendant functionality through the use of TCL scripts. This is built in to CME. See the following link.
If you use Unity Express voicemail along with CME, it also has AA features.
Hope this helps. If so, please rate the post.
Brandon
moabdallah Tue, 02/13/2007 - 03:51
Hi Brandon,
Without Unity Express, how many AA ports does the CME support ?
Mohamed
Brandon Buffin Tue, 02/13/2007 - 05:51
Mohamed,
Here are the limits for B-ACD.
Any number of AAs
1 call queue
10 hunt groups
3 hunt groups per AA
30 calls queued per hunt group
So, you could have a maximum of 300 calls queued at any time (10 hunt groupos x 30 calls per hunt group).
Hope this helps.
Brandon
kumarss77 Thu, 04/19/2007 - 08:04
Some more details on this please.
suppose we have say 5 different small companies using the same call manager express. Can we have 5 different Auto Attendants and associated 5 call queues working at the same time (using CME alone)?
Brandon Buffin Thu, 04/19/2007 - 10:21
You could have 5 different AAs, but only 1 queue. See the limits mentioned in the previous post.
Brandon
