Using RTMT to watch Gateway Load
Feb 12th, 2007
I was asked to look for a way to get Report on our E1 links of our H323 Gateways. So i tried using RTMT (Call Activities Reports Archive) and got the attached diagram as Result.
Can anyone tell me how this Diagramm can tell me if our 4 E1 (120 Channels) are enough or should we consider putting other E1 link on the Gateways
Overall Rating: 2.5 (2 ratings)
Stoyan Stoitsev Tue, 02/13/2007 - 02:24
If the above diagram really shows only the calls out of your E1 interfaces, then you have at least 7 E1 interfaces so you can reach the 200 simultaneous calls.
Generally you need gateway utilization statistics - attempted and completed calls. Then you have to calculate your Erlangs - check that site http://www.erlang.com/calculator/index.htm on how to do this.
You can also try this cisco link http://www.cisco.com/iam/unified/ipt1/Develop_Traffic_Engineering_Specifications.htm
Jayd000007 Tue, 02/13/2007 - 07:24
I did the Math, found out i need 60 to 80 Lines, we have 4 E1=120, so i thought we should be fine.
I used RTMT (H323 Active Calls) and it showed me a MAX of 60 on Busy Hour.
The CDR Statistic (Gateway Utilization) show also 100% of link are used, which is seems not true.
is it a Bug on those Reports (Gateway Utilization and Call Activities? Or am i missing something?
Stoyan Stoitsev Wed, 02/14/2007 - 04:17
In CDR you should specify how many ports you have on that h323 gateway
System>System Parameters>Gateway Configuration
Jayd000007 Wed, 02/14/2007 - 04:23
I already did that, i specified in CDR: 60 ports (2E1) for each Gateway we have.
redrobish Tue, 05/15/2007 - 18:09
Hi Jayd000007,
How did you get the report on the Gateway on RTMT? Can you pls. teach me how to get that "diagram report" ?
thanks
Zin.Karzazi Wed, 05/16/2007 - 03:16
On your CCM webadmin page:
Got to aplication->Cisco Callmanager Serviceability->Tools->Serviceability Report Archive
Karzazi
redrobish Wed, 05/16/2007 - 15:09
Tnx Zin,
All I can see is alert reports. Maybe it's not setup in my CCM. Could you pls. teach me how?
thanks
