error upgrading IDSM2 5.1(4) past s261
Feb 12th, 2007
I have a 6500 IDSM2 at 5.1(4) + S261. When I attempt to upgrade to S267 or S268, I get the error msg:
Error: execUpgradeSoftware : Error status returned with status str Internal Error.
I have rebooted the IDS - no difference. I'm using "upgrade http:" with http sw which has always worked in the past. What should I look at?
jamesand Mon, 02/12/2007 - 16:31
You could try the same sigupdate using ftp or scp as the file transfer protocol. If this fails, then you will probably need to generate a "show tech" and open a cisco tac case.
acomiskey Tue, 02/13/2007 - 07:57
I assume you're using the "minreq-5.1-2.pkg" filename for version 5 sensors?
csthomas Tue, 02/13/2007 - 11:18
Yes, the sig update I tried is:
IPS-sig-S268-minreq-5.1-2.pkg
I suppose I could consider imaging the IDS up to v6, which would probably avoid the problem.
csthomas Wed, 02/28/2007 - 15:32
Further info: I reimaged the sensor to v6. Same error.
It appears that UPGEADE HTTP: is no longer supported for sig application. As soon as I tried an UPGRADE FTP:, everything works.
