Upgrading ACS from 3.2.1 to 3.3.3
Feb 12th, 2007
Hi... It appears that in order to upgrade from 3.2 to 4.1, I need to do an intermediate upgrade to 3.3.3 before going to 4.1.
My question is, does anyone know of any known issues or caveats to doing an in-place upgrade from 3.2 to 3.3.3 while preserving the database?
Thank you.
Overall Rating: 4 (1 ratings)
darpotter Mon, 02/12/2007 - 13:12
Should be fine.. but make sure you create an ACS backup at each stage.
This will allow you to re-start from any stage just in case of a problem.
Make sure you're a local (rather than domain) admin and if using RDP use the console.
Good luck!
