FWSMs on 6513
Fernando_Meza Tue, 02/13/2007 - 02:13
Hi ..
definetely .. you can connect to any module that allows interactive access using the session command .. do a show module and identify the slot your need to connect. If you need to connect to more than one module at the same time using the session command then you could have two separate remote sessions to the supervisor and from there open a session to every FWSM respectively
I hope it helps .. please rate if it does !!
varakantam Tue, 02/13/2007 - 10:20
Aksher,
You could either use session slot x proc 1 or if you pull out the blade there is a hidden console on the blade. You could connect a serial cable to connect and get on the physical console of blade.
Jon Marshall Tue, 02/13/2007 - 10:30
The show module command will not work on the FWSM. You need to exit back out of the FWSM to the switch then session to another of your FWSM's.
You cannot session from one FWSM direct to another FWSM as far as i know.
Jon
