Unity Connection and CME supervised transfer
Feb 12th, 2007
i'm having a problem getting unity connection to perform a supervised transfer. it is performing a release to switch even if i select supervised transfer.
eschulz Mon, 02/12/2007 - 12:07
In the Set Up Port Group Page do you have the Server Type set to "Cisco Unified CallManager Express"?
Worth checking because that is a commonly missed setting that will have a direct impact on transfers.
-Eric
