ASA internal vpn access
Feb 12th, 2007
Hi!
I have a couple vlans on the inside that are confiured in an router, it is also def-gate to all clients. Further there is a link net (172.16.200.0/24) to the ASA 172.16.200.10 (also def-route on the router). There is no access between vlan 10 and 20 and i cannot use access-list in the router for this. Instead i tried to use vpn client to get this access, but this demands that traffic enter and exit inside interface 172.16.200.10. An ip pool is created (10.10.10.0 also have access to all vlans). But i get the following error "No translation group found"
Does anyone now if this solution is possible? /Regards
Kamal Malhotra Mon, 02/12/2007 - 17:12
With the description, the issue is not completely understood. Please elaborate it.
Kamal
