Cannot forward message in Unity
Feb 12th, 2007
I have a Unity 4.2 installation that is having a problem forwarding message. It appears to be affecting all users.
A user wants to forward a voicemail to another users. They address the message and record a preamble to the original message. Once done the press # to send the message. Uity replies wit the following message. "Unable to forward your message at this time."
Has anyone seen this before. I have check the Event log and the only message I can see is the following.
IAvDohMessage::Submit returned [0x800404dc] on line 1047 of file E:\Views\CU4.2.0.110\un_Core2\ConversationEng\AvStateSvr\AvSMsgSend.cpp
mrmccann Mon, 02/12/2007 - 23:15
This is likely a permissions issue. Did you run the latest version of Permissions Wizard when you installed/upgraded to Unity 4.2?
If you did run Permissions Wizard, then make sure the OUs that contain your Unity subscribers have "allow inheritance" enabled.
If that doesn't fix the issue, make sure your Unity subscribers have "allow inheritance" enabled. Also make sure Unitymsgstoresvc and Unitydirsvc accounts have "allow inheritance" enabled.
chevymannie Wed, 06/27/2007 - 09:58
I work with the young lady that sent the original message. We've checked the permissions and they are as you suggested the users are still not able to forward the messages.
