Netflow Question
Feb 12th, 2007
I want to start using Netflow data in my Network Management and I had a few questions.
1. How do I know if my devices are capable? Is there specific hardware platforms or IOS features that I need to have installed?
2. Is there a doc out there that I can reference to show me how to configure/enable Netflow?
Thanks!
albert.remo Mon, 02/12/2007 - 23:06
b.bipinlal Thu, 02/15/2007 - 05:22
hi,
i am not able to login this link , i have cisco id (ccna) . And i am not able to download any secured soft ware also from cisco site can u guide me n=hwo to enable this??
albert.remo Thu, 02/15/2007 - 19:52
Hi!
I believe you can access the given links without logging-in on the Cisco Website. Just click on the links. I believe that there are certain requirements such as being a partner or buying a cisco product to be able to create a login.
Albert
