backup interface problem
Feb 12th, 2007
I have a Cisco 2811 router,which has 2 fastethernet ports ,WIC-1T card.
1. WIC-1T is connected to teh ISP by means of 128KB leased line.
2. Fastethernet 0 is configured with Public STatic IP and connected to a switch,where 5 usres are connected with public IP.
3. Then the second fastethernet 1 interface is connected to a ADSL modem provided by the same ISP.
Now I want to configure this fastethernet 1 as the backup interface for teh Serial interface.
Please guide me how to achieve this.
Thanks and Regards,
S.Venkataraman
Anonymous (not verified) Fri, 02/16/2007 - 14:10
Why do you want to configure your fast ethernet interface as the backup interface to the serial interface?? Normally only a serial interface should be used to act as a back up for another serial interface. You cannot configure a fast ethernet interface as a backup for serial interface.
Lavanholy Fri, 02/16/2007 - 20:05
Hi Joas,
Thanks for your info.I have completed day before yesterday.It is working fine.I have 2 Fastethernet and 1 WIC-1T,The WIC-1T is connected to ISP.
F0/1 is assigned as the global public IP and it is attached to the PROXY server's one of the NIC which is also assigned as the Global Public IP.
F0/0 is defined as the backup interface for the Serial interface,F0/0 is private IP to which LAN interface of the ADSL is attached whose IP also in the same subnet IP of F0/0.
Now whenever the serial interface is down teh fastethernet 0/0 is coming up and we are able to access the Internet.
Thanks a lot.
Best Regards,
S.Venkataraman.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
