Block Website and Messenger - URGENT
Feb 12th, 2007
Hi All,
I am still new to firewall, I have CISCO PIX 515 firewall. My management asked me to block Yahoo mail, Hotmail, and other websites. Also the asked me many times to block MSN, Yahoo, AIM and other messengers.. How I can do that using pix firewall... this is very urgent for me...
Rami
rleivaoc Mon, 02/12/2007 - 23:26
If you are running 7.2 you can block IM using the "inspect IM" feature. Here is a link that shows the "inspect IM" command options, http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/cmd_ref/i2_711.htm#wp1658250
However, I don't think it supports all the IM programs. If you wish to block more, you will need to create an ACL to block those application ports.
Now, for filtering Yahoo, and Hotmail email websites, you will need to either get a Websense solution or the Cisco CSC module, both have very good HTTP filtering options. I hope this helps.
ramiqutub Mon, 02/12/2007 - 23:38
Thanks for the reply. I am using version "Cisco PIX Security Appliance Software Version 7.0(2)".
As for the websense, I will take a look and get back to you if I have more questions.
Thanks, many thanks
daviddtran Wed, 02/14/2007 - 19:13
I could not help but jumping into this conversation.
Yes, Pix 7.x can block Yahoo or MSN using http
port; however, it can NOT block other IM traffics such as ICQ or AOL IMs. These IMs
APPs can use ports such as telnet (23) or
smtp (25) to connect to the server. Pix/ASA
will not be able to accomplish what you
requested. What you really need is a
checkpoint firewall. The SmartDefense which
is integrated into CP firewall that can block
these IMs in a heartbeat.
As far as blocking sites such as yahoo or
hotmail, again, I don't think pix/ASA is
capable of doing that. Again, what you need
is a Checkpoint or Juniper Firewalls that
is capable of doing just that. You can
specify domain as the destination and the
firewall will do a reverse dns lookup and
drop connections to yahoo or hotmail in a
heartbeat.
