When VPN eastablish then no ping
Feb 12th, 2007
HI
I am facing a picular problem.
I have two site connect through local ISP.
site A: Wan IP 192.168.10.5
lan Ip: 10.10.20.0
site B Wan IP 192.168.11.5
lan Ip: 10.10.30.0
when no vpn then every site can ping each other.
But when I create vpn with
192.168.10.5 and 192.168.11.5 then peer to peer vpn eastablish and ping each other with data encrypt. when I add lan ip both side in ACL then LAN to LAN can not ping even when delete ACL then time no ping. again when i assign no crypto then again all r ping each other !
any one have suggation ?.
thanks
Biplob
spremkumar Mon, 02/12/2007 - 23:18
What kinda equipments you are using up over there ?
Can you also post the configs of the respective devices ?
regds
kaachary Wed, 02/14/2007 - 05:51
Hi..
Sounds like your crypto acl is setup incorrectly..
It should be something like :
access-list 101 permit ip 10.10.20.0 0.0.0.255 10.10.30 0.0.0.255
HTH,
Kanishka
