VPN Client is keep disconnecting
Feb 12th, 2007
I have windows based vpn software client, it keep disconnecting from the vpn router 1721. I have found the following message on router:
%CRYPTO-6-IKE_TED_BAD_REPLY: Received TED reply that did n
ot correspond to a TED probe
Please help me regarding this message.
thanks
Muhammed Imran
smalkeric Fri, 02/16/2007 - 14:13
A TED reply was received that does not match a TED probe that is pending. This condition may be a one-time occurrence due to a delay of the the TED reply or ill-formed packets sent by the peer. This condition might be considered a hostile event.
It could be keepalive problem : try this
going to %System Root%\Program Files\Cisco Systems\VPN Client\Profiles on the Client PC that experiences the issue, and edit the PCF file (where applicable) for the connection.
Change the 'ForceKeepAlives=0' (default) to 'ForceKeepAlives=1'.
what version of VPN client you are using?
Try this:
http://www.cisco.com/warp/public/471/ios-unity.html
Kamal Malhotra Fri, 02/16/2007 - 14:58
Hi Muhammed,
You might also want to try this :
1. Modify the connection entry in the VPN client.
2. Goto Transport tab.
3. Set the 'Peer Response Timeout' to 480. Default is 90.
HTH,
Kamal
