IPCC Enterprises 7.0 with CVP
Feb 13th, 2007
Hi All, I am new to this forum as well on IPCC also. I need help if somebody can suggest me, what is is the Day to day Opration for the IPCCE Engineer to perform? In My IPCCE Infrastructure I have following components:
5350XM VXML GW with PGW2200 softswitch, 3845 GK, CSS 11503, CALL Manager 4.1, CVP 3.1,ICM 7.0, PG's. (For the Documention Purpose)
Thanks in Advance
Overall Rating: 4 (2 ratings)
musakazim Thu, 02/15/2007 - 07:47
Day to day task for an IPCC engineer totally depends on individual.
I can try and highlight some task
 Anti Virus update on the windows servers (as per Cisco recommendation)
 Making few inbound and outbound calls at the start of the day, just to make sure every thing is in place.
 Logging on Gateway and check the calls, ISDN status if all the ISDN interfaces are active and taking calls as you expected.
 Jump on to the Gatekeeper and have a look, if all the expected endpoints are registered with GK.
 Check which side of PG is active, if there was a fail over investigate the cause for it.
 Check the event log message on all Windows servers to find out if there was any issue.
 If your using Cisco works, check if its backing up the IOS data as expected.
 If you?re using any SNMP tool, check the events to find if there was any issue over night.
This are just day to day health check advice, I am sure you can do a lot in IPCC. Best of luck
Musa
Zin.Karzazi Thu, 02/15/2007 - 09:08
For Callmanager:
- Check RTMT Emails Alerts
- Check your (daily?)BARS Backup
- Server Report(CPU, Memory), Call Activities, Gateway Activities (Application->Callmanager Serviceablity->tools->Serviceability reports)
- Use DNA, SDI/SDL traces..etc
- once in a while get your Route Plan (*xls), check for unused DN (unassigned DNs)
- Setting a Lab Envirement would be the best if you are a newbie.
- CDRs (Gateway Utilization, QoS, ..etc)
- Read the SRND!!!
For IPCC Ent:
- Always be prepared for a "worst case" Scenario (depends on the Design of your IPCC)
- You should know how to collect logs from your PIMs,PGs, Router, Logger. How to use Dumplog Utility/ CTITEST / SQL Analyzer to troubleshoot day to day issues
- Ensure that Webview (or using SQL Analyzer) are showing the right statistics.
- Check Databases Backup
- Use ICM Script to Monitor your Call Flows.
- Read the SRND!!!
Last Advise: Stay Cool ;)
hope this helps
Zin-Elabidine Karzazi
shyamkumar.puppala Sat, 02/17/2007 - 22:26
ThanQ very much for ur advise. If u can guide me with some more details to be as successfull IPCC Engineer. Like general problems.....
