IDS Viewer Web problems
Feb 13th, 2007
All,
I have installed IPS Event Viewer and the sensors are connected but when i double click on the event viewer only a blank https screen displays.
This is the same for both Primary and secondary IDS modules in a Active Passive failover system.
I am running IE6 and tried IE7 but no joy.
Java is installed and activeX controls are at prompt
Sensor Version
Cisco Intrusion Prevention System, Version 6.0(1)E1
Host:
Realm Keys key1.0
Signature Definition:
Signature Update S267.0 2007-01-23
Virus Update V1.2 2005-11-24
Platform: ASA-SSM-20
Booted Partition: application
Application Partition:
Os Version: 2.4.30-IDS-smp-bigphys
Applications
MainApp
2006_Dec_11_11.57 2006-12-11T12:44:38-0600 Release
Execution State: running
AnalysisEngine
Installed Upgrades
IPS-K9-6.0-1-E1 11 December 2006 11:57:00 UTC
IPS-sig-S267-req-E1.pkg 29 January 2007 03:38:54 UTC
Next Downgrade:
Recovery Partition:
Build Version: 1.1 - 6.0(1)E1
PEP Udi:
desc: ASA 5500 Series Security Services Module-20
pid: ASA-SSM-20
vid: V01
sn: JAF1025xxxx
Web Server Statistic Information
listener-443
session-4
remoteHost remote host = 10.137.1.7
isKeepAliveActive session is persistent = yes
keepAliveReqs number of requests serviced on current connection = 4
lastError last status code = 200
requestMethod last request method = GET
uri last request URI = cgi-bin/sdee-server
version last protocol version = HTTP/1.1
sessionState session state = processingGetServlet
session-3
keepAliveReqs number of requests serviced on current connection = 3
requestMethod last request method = POST
uri last request URI = cgi-bin/transaction-server
sessionState session state = processingPostServlet
serverRequestsHandled number of server session requests handled = 65
serverRequestsNotHandled number of server session requests rejected = 0
totalRequestsHandled total HTTP requests handled = 306
connectionsAllowedPerPort maximum number of session objects allowed = 40
availableSessions number of idle allocated session objects = 8
inUseSessions number of busy allocated session objects = 2
cryptoVersion crypto library version = 6.2.1.0
SDEE Server Statistic Information
General
Open Subscriptions = 1
Blocked Subscriptions = 1
Maximum Available Subscriptions = 5
Maximum Events Per Retrieval = 500
Subscriptions
sub-2-38fb6de1
State = Read Pending
sbilgi Mon, 02/19/2007 - 06:44
Possible reasons could be the following:-
1. You may not have rebooted the server after install
2. Terminal services seems to be enabled while installing which is not supported
3. The product may not be upgraded properly.
Try these link:
http://www.cisco.com/en/US/products/sw/cscowork/ps3990/products_user_guide_chapter09186a008018d92d.html
http://www.cisco.com/en/US/products/sw/cscowork/ps2330/products_qanda_item09186a00802c2a10.shtml
