telnet into CSS
Feb 13th, 2007
Hello
I am trying to set up remote access to my CSS via Telnet through a mgmt port.
I have configured an ip address, subnet mask and default gateway on the mgmt port
!************************ BOOT CONFIG ************************
ip address 192.168.1.1
subnet mask 255.255.255.0
gateway address 192.168.1.254
primary boot-file sg0740004
primary boot-type boot-via-disk
When i am trying to telnet in to the CSS from the default gateway everything works fine, but when I have tried to access it from the mgmt station that is not connected to the router I fail, despite that mgmt station can easily ping the ip address of the CSS default gateway.
It looks like the "gateway" command in the boot configuration of the CSS does`t work.
Thank You for any help in advance.
Lukas
Gilles Dufour Tue, 02/13/2007 - 04:24
the gateway command under the boot config is only used when hte CSS boot in order to do a software recovery.
You can configure static route on the management port but no default gateway.
Also, there can't be overlapping between route in managment and route in standard interfaces.
To create the management route, use the command:
CSS11503-2(config)# ip management route ?
Route prefix
Gilles.
lukaszkhalil Thu, 04/19/2007 - 22:23
I believe the "show ip route" shows all the routes including mgmt routes.
Lukas
lukaszkhalil Thu, 04/19/2007 - 23:08
I`ve just execute "sh ip route" and "sh run" in the lab and i `ve attached the results below.
In both command you can see the mgmt routes.
Gilles Dufour Fri, 04/20/2007 - 01:40
if you want to see the management config, do a 'sho boot'.
As for the initial question, the gateway configured for the management interface [in the boot config] is only for the boot process to locate a tftp server.
Once the software is loaded, the gateway is not being used.
The ip management route can be used and should see them in the routing table and in the config.
Gilles.
