Configuration RSVP
Feb 13th, 2007
Got some problems with RSVP configuration on pilot.
The first PATH message is sent but the return PATH is not.
Topology :
PBX -- R1(Gw/Gk) -- R2(Wan) ----- R3(Wan) -- R4(Gw/Gk) -- PBX
Here are configurations files:
R3_Site1_Zone2#sh tech
------------------ show running-config ------------------
Building configuration...
Current configuration : 2000 bytes
version 12.3
hostname R3_Site1_Zone2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip domain lookup
no ftp-server write-enable
username pat password 0 <removed>
class-map match-any gold
match dscp af31
match access-group 101
class-map match-any voice
match dscp ef
policy-map qos
class voice
priority 200
class gold
bandwidth 150
class class-default
fair-queue
interface FastEthernet0/0
duplex auto
speed auto
fair-queue 64 256 1
ip rsvp bandwidth 20 20
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
bandwidth 512
no ip address
encapsulation frame-relay
load-interval 30
no keepalive
no fair-queue
frame-relay traffic-shaping
frame-relay ip rtp header-compression
ip rsvp bandwidth
interface Serial0/1/0.1 point-to-point
ip address 10.0.0.2 255.255.255.192
ip ospf network point-to-point
frame-relay interface-dlci 17
class to-zone1
ip rsvp bandwidth
ip rsvp data-packet classification none
ip rsvp resource-provider none
router ospf 113
log-adjacency-changes
network 10.0.0.0 0.0.0.63 area 1
network 192.168.1.0 0.0.0.255 area 1
ip classless
ip http server
no ip http secure-server
map-class frame-relay to-zone1
frame-relay cir 512000
frame-relay bc 51200
frame-relay be 0
frame-relay mincir 512000
frame-relay adaptive-shaping becn
service-policy output qos
map-class frame-relay to-site1
access-list 101 permit udp any any eq 1200
control-plane
line con 0
password <removed>
login
line aux 0
line vty 0 4
absolute-timeout 1000
login local
end
b.hsu Mon, 02/19/2007 - 06:49
RSVP Reservation Types
These are the two types of multicast flows:
Distinct reservation. This constitutes a flow that originates from exactly one sender.
Shared reservation. This constitutes a flow that originates from one or more senders.
RSVP describes these reservations as having certain algorithmic attributes.
Distinct Reservation
An example of a distinct reservation is a video application in which each sender emits a distinct data stream that requires admission and management in a queue. Such a flow, therefore, requires a separate reservation per sender on each transmission facility it crosses (such as Ethernet, a High-Level Data Link Control (HDLC) line, a Frame Relay data-link connection identifier (DLCI), or an ATM virtual channel). RSVP refers to this distinct reservation as explicit and installs it using a Fixed Filter style of reservation.
Use of RSVP for unicast applications is generally a degenerate case of a distinct flow.
Shared Reservation
An example of a shared reservation also is an audio application in which each sender emits a distinct data stream that requires admission and management in a queue. However, because of the nature of the application, a limited number of senders are sending data at any given time. Such a flow, therefore, does not require a separate reservation per sender. Instead, it uses a single reservation that can be applied to any sender within a set as needed.
RSVP installs a shared reservation using a Wild Card or Shared Explicit style of reservation, with the difference between the two determined by the scope of application (which is either wild or explicit):
The Wild Card Filter reserves bandwidth and delay characteristics for any sender and is limited by the list of source addresses carried in the reservation message.
The Shared Explicit style of reservation identifies the flows for specific network resources.
Planning for RSVP Configuration
You must plan carefully to successfully configure and use RSVP on your network. At a minimum, RSVP must reflect your assessment of bandwidth needs on router interfaces. Consider the following questions as you plan for RSVP configuration:
How much bandwidth should RSVP allow per end-user application flow? You must understand the "feeds and speeds" of your applications. By default, the amount reservable by a single flow can be the entire reservable bandwidth. You can, however, limit individual reservations to smaller amounts using the single flow bandwidth parameter. The reserved bandwidth value may not exceed the interface reservable amount, and no one flow may reserve more than the amount specified.
How much bandwidth is available for RSVP? By default, 75 percent of the bandwidth available on an interface is reservable. If you are using a tunnel interface, RSVP can make a reservation for the tunnel whose bandwidth is the sum of the bandwidths reserved within the tunnel.
How much bandwidth must be excluded from RSVP so that it can fairly provide the timely service required by low-volume data conversations? End-to-end controls for data traffic assume that all sessions will behave so as to avoid congestion dynamically. Real-time demands do not follow this behavior. Determine the bandwidth to set aside so bursty data traffic will not be deprived as a side effect of the RSVP QoS configuration.
Try:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800b75bb.html
