Looking for a program to change phone ring tones
Answered Question
Feb 13th, 2007
I have a document to create and change phone ring tones in CCM 4.1
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_0/admin_gd/3_0_9/a3rings.htm
but in this document say me the correct format that ring tones would have to run properly in CCM and I need a program to do it. I don't know how I will do it.
Anybody can help me?.
Thanks.
Correct Answer by Brandon Buffin about 9 years 7 months ago
You can use any program that lets you record and edit audio. Sound Recorder in Windows will do the job.
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Tue, 02/13/2007 - 05:56
Brandon
