Both the Nodes in HSRP should be standby
royalblues Tue, 02/13/2007 - 05:18
Raju,
You cannot have both the routers are HSRP stanby. One router will act as active and the other one as standby.
BTW, what sort of testing requires this setup ?
Narayan
devang_etcom Tue, 02/13/2007 - 07:01
that is the case when you have loadbalancing with the HSRP. Its like one node is active for the one VLAN/Subnet or you can say for one HSRP group... and Standby for the other VLAN/Subnet or other HSRP group... and other host is having active or standby status for the different VLN/Subnet or Group... in that case node is active as well as standby but for the different variable...
regards
Devang
