Routing Issue with backup
Feb 13th, 2007
I have configured DSL PPPoE with WAN IP 11.1.1.5/32 and routed a subnet
12.1.1.0/24 (on my BRAS router). Same Pool has been routed towards ISDN as
backup (on my DIST router). The problem occurs when PPPoE goes down, routing
entry dose not take backup ISDN path. The reason behind is that my BRAS gets
next hop WAN pool 11.1.1.0/24 from Core router i.e. towards Null0 for BGP advertisment
Kindly suggest me the changes to overcome this problem. Also see attached
Diagram for better understanding.
mheusinger Tue, 02/13/2007 - 05:44
you should be able to solve the problem with a floating static for 11.1.1.5/32 on your BRAS pointing to your DIST router. Finally all you want is to get the packets down to your DIST router, which will then route it through the backup to the 12 network.
Did not test it, but seems worth a try. Longest match routing should then prefer /32 over the 11.1.1.0/24 announced in BGP.
Hope this helps! Please use the rating system.
Regards, Martin
Regards, Martin
