Cisco Secure ACS problem
Feb 13th, 2007
We have Cisco Secure ACS 4.0 which authenticates wireless users with certificate. Sometimes I get a message in failed attempts:
02/13/2007 14:22:38 Authen failed EAP-TLS or PEAP authentication failed during SSL handshake
02/13/2007 14:22:17 Authen failed EAP-TLS or PEAP authentication failed during SSL handshake .. ..
After few retries user can authenticate normaly without any change. If I check the ACSauth log i see for the same timeing:
AUTH 02/13/2007 14:21:55 A 5082 2644 Worker 4 waiting for work
AUTH 02/13/2007 14:21:56 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: error decrypting non fragmented data.
AUTH 02/13/2007 14:21:56 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: SSL send alert fatal:unexpected_message
AUTH 02/13/2007 14:22:04 E 5103 2616 AllocateThread returned 0
AUTH 02/13/2007 14:22:04 A 5086 2628 Worker 0 established conn 67109 with 127.0.0.1:8515
AUTH 02/13/2007 14:22:04 E 5103 2616 AllocateThread returned 2
AUTH 02/13/2007 14:22:04 A 5086 2636 Worker 2 established conn 67110 with 127.0.0.1:8518
AUTH 02/13/2007 14:22:04 E 5103 2616 AllocateThread returned 4
AUTH 02/13/2007 14:22:04 A 5086 2644 Worker 4 established conn 67111 with 127.0.0.1:8526
AUTH 02/13/2007 14:22:04 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: error decrypting non fragmented data.
AUTH 02/13/2007 14:22:04 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: SSL send alert fatal:unexpected_message
AUTH 02/13/2007 14:22:07 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: error decrypting non fragmented data.
AUTH 02/13/2007 14:22:07 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: SSL send alert fatal:unexpected_message
AUTH 02/13/2007 14:22:10 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: error decrypting non fragmented data.
AUTH 02/13/2007 14:22:10 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: SSL send alert fatal:unexpected_message
AUTH 02/13/2007 14:22:17 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: error decrypting non fragmented data.
AUTH 02/13/2007 14:22:17 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: SSL send alert fatal:unexpected_message
AUTH 02/13/2007 14:22:38 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: error decrypting non fragmented data.
AUTH 02/13/2007 14:22:38 E 0361 2652 EAP: PEAP: getEapMsgFromPeapTunnelFrag: SSL send alert fatal:unexpected_message
AUTH 02/13/2007 14:23:04 A 5096 2640 Worker 3 error/timeout, forcing API disconnect of connection 67105.
AUTH 02/13/2007 14:23:04 A 5097 2640 Worker 3 closing conn 67105 endpoint. Handled 6 messages.
AUTH 02/13/2007 14:23:04 A 5096 2636 Worker 2 error/timeout, forcing API disconnect of connection 67110.
AUTH 02/13/2007 14:23:04 A 5082 2640 Worker 3 waiting for work
AUTH 02/13/2007 14:23:04 A 5097 2636 Worker 2 closing conn 67110 endpoint. Handled 4 messages.
AUTH 02/13/2007 14:23:04 A 5082 2636 Worker 2 waiting for work
AUTH 02/13/2007 14:23:04 A 5096 2628 Worker 0 error/timeout, forcing API disconnect of connection 67109.
AUTH 02/13/2007 14:23:04 A 5097 2628 Worker 0 closing conn 67109 endpoint. Handled 12 messages.
AUTH 02/13/2007 14:23:04 A 5082 2628 Worker 0 waiting for work
AUTH 02/13/2007 14:23:04 A 5096 2644 Worker 4 error/timeout, forcing API disconnect of connection 67111.
Can anyone explain what could be the problem here?
thanx in advance
best regards,
Gregor
