Ip accounting On Cisco 7613 router
Feb 13th, 2007
IP accounting on Cisco 7613 is not giving any output. Is there any other command on cisco 7613 to check the traffic flow on a particular interface of 7613 which can show the source and the destination for the traffic flow.
Overall Rating: 1 (1 ratings)
miclacs13 Tue, 02/13/2007 - 19:42
You must activate the command "ip accounting output-packets" under the particular interface you want to monitor on the "interface config-line";
Afterwhich, to view the accounting..simple issue "show ip accounting" on the console.
Hope this helps.
Br,
Mike
