Mitel Voicemail Integration options
Feb 13th, 2007
Hello all,
I researching a solution for a Mitel customer and I am specifically looking for Voicemail integration options into their "Mitel Messaging Server 6510". They are useing a Mitel 3300 PBX for their CallProcessing, which we can integrate via QSIG or PRI to CallManager.
What I don't know is the following
Can the customer continue to use their Mitel 6510 VM server with Cisco Phones?
I only found one artical on this option and it was ugly and scary and I can't see Cisco supporting it. http://voipspin.net/2006/04/28/voicemail-integration-cisco-fujitsu-and-mitel/
Can we use Unity for Cisco phones and Mitel 6510 for Mitel phones and Network the two systems?
I found references that Mitel supports VPIM but again not on Cisco's site, any other options AMIS? Anybody else doing this?
Can we use Unity for Cisco phones and Mitel phones?
Yes we can i think using PIMG or Voice Dialogic cards in Unity Yes / No ?
Comments and or experiences with Mitel integration would be great
