IP phone services CallManager 5.1
Overall Rating: 4 (1 ratings)
thisisshanky Tue, 02/13/2007 - 09:34
You dont need the fast dial urls ay more. You can access this via personal directory that shows up as Option 4 when you hit the directory button on the phone. YOu will be asked to authenticate using username and pin. Once you log in you can access PAB and fast dials.
If you still want to use the URL, setup the IP phone service as follows.
http:///ccmpd
You will be forced to authenticate using username and pin.
Sankar.
PS: please remember to rate posts!
CHRISTOPHER YUEN Wed, 03/14/2007 - 10:19
When using that url, I'm getting to the page which asks for the PAB or Fast Dials or Logout. If I hit Fast Dials, I get "Your session has time out, please login again".
Have you seen this before? Thx!
thisisshanky Wed, 03/14/2007 - 11:31
Can you try browsing to the url on a web browser ? Do you see xml output in your browser ? I am able to. and when i use this url on the phone, it asks me for username and pin.
CHRISTOPHER YUEN Wed, 03/14/2007 - 11:43
Thanks for your response...
Yes I can pull it up on a browser. I get the xml code listing the three options.
When I use it from phone, I keep getting that error regarding my session timing out, and to login again.
For Fast Dials, are the user ID and pin parameters still valid?
thisisshanky Wed, 03/14/2007 - 12:20
Yes they should be valid.
I will re-test this again today if possible and let you know.
I think Cisco is phasing out the URL method of accesing PAB and fast dials. Thats why you see the Personal directory option (4) when you hit the directory button
Mike Iversen Fri, 03/16/2007 - 08:46
Cisco has phased out the URL Method.
Instead of pressing one button to get to your fast dials now you get to press 4.
Directores, 4, login password, then choose either fast dials or address book. I'm amazed that Cisco considers this "easier" to use than 4.x fast dials.
Mike
thisisshanky Tue, 04/03/2007 - 20:46
Mike,
I agree, not sure why Cisco would call this "Fast dial" when its not so fast...the very reason that you have to login using username and pin itself prevents\ end-users from using this feature.
Abid Abdul Latif Thu, 03/15/2007 - 11:01
can you please help me to get url for DND service and from where i can get list of all available URL's for adding any service.
thisisshanky Tue, 04/03/2007 - 20:47
DND key works only with IPMA if using callmanager. You can add this to a custom softkeytemplate and apply the softkey template to the desired phones.
