ACE - removing script from ACE memory
Feb 13th, 2007
I played with scripted probes and now I can't remove script from ACE memory... because I have no 'script file NN SCRIPT_NAME' in my running config, therefore I can't remove script from memory with 'no script file NN'.
When I try delete file from disk0: and upload modified file (with the same file name), 'sh file disk0:SCRIPT_NAME' shows correct file content, but 'sh script code SCRIPT_NAME' is wrong (because script is loaded in memory).
How it's possible to unload script from memory if no 'script file NN script_name' in running config exists?
martin
Gilles Dufour Wed, 02/14/2007 - 02:24
Martin,
this is a bug.
The 'no script file ' should be enough to remove the script from memory.
I checked the code and this is something that can easily be fixed.
I will submit a new ddts.
Thanks for pointing this issue to us.
Gilles.
