How do you add a pause into a speed dial?
Feb 13th, 2007
luisalva Tue, 02/13/2007 - 10:12
In Callmanager Service parameters there is a setting call "Speed Dial Await Further Digits* " you can set it to "true".
This parameter specifies whether Cisco CallManager waits for further digits before extending the call when a call is initiated via use of a speed-dial button. If additional digits are not received by the time that the value that is specified in the T302 Timer expires, Cisco CallManager tries to connect the call by using just the speed-dialed digits. Valid values specify True (Cisco CallManager accepts the speed-dial number and awaits further digits) or False (Cisco CallManager immediately extends the call by using the number that is specified in the speed-dial button that the user pressed).
This is a required field.
Default: false.
This is cluster wide setting.
-Luis
