OWA CSS11501 and ssl termination
Feb 13th, 2007
Is it possible to use the css to load balance for OWA and offload SSL ?
have tried this and it appears to break OWA even though other web apps work ok through same CSS.
When removing ssl termination could only make load balancing work when incoming tcp port on the content rule and outgoing tcp port to OWA server were set to 80.
If content rule port was set to anyhting other than 80, OWA breaks.
guess there is some form of embedded redirection going on.
alpritchard Mon, 02/19/2007 - 23:44
have set up many CSS load balancers so the basics are all in place.
OWA though appears to be a bit different, in terms of it using http 302 redirection.
This makes the client session bypass the VIP
Gilles Dufour Tue, 02/20/2007 - 11:26
what kind of redirect do you get ?
Your server can send redirect, but it should use the vip address name and not the server name or server ip.
Many people are loadbalancing OWA successfully.
You may have to check the server config.
Gilles.
Gilles Dufour Wed, 02/21/2007 - 05:14
if all you need is replace the http with https, you can use the urlrewrite function.
A quick search in the configuration guide will show you how to use this command.
Gilles.
