ISIS ACL
Feb 13th, 2007
I'd like to know how can I configure a ACL to permit the isis routing protocol?
In the acl there is no ISIS like OSPF
sbilgi Mon, 02/19/2007 - 11:46
The ISIS protocol use protocol identifier of 0x83, it is a layer 2 identifier. IS-IS does not run over IP. You would need to use an ACL in the 200-299 range, matching on the L2 Protocol type.
You might look into the CLNS filters to do this.... 'clns filter-expr' and 'clns filter-set'.
Refer this link:
http://www.cisco.com/en/US/products/ps6350/products_command_reference_chapter09186a0080449b9a.html#wp1018279
