VPN connection keeps dropping
Feb 13th, 2007
I have a PIX 501 that is connecting to our main ASA 5510. The 5510 is the hub and the 501 is the spoke in our VPN setup. All other spokes in our network are working fine. One of our sites is having a problem. The PIX will load up, and work for just a few seconds, then will cease to connect. The PIX is still powered on and we are able to telnet in, show int on E0 lists up and up. We are not however able to SSH into the PIX, but we CAN ping the external interface. We tried reloading, which works for a few seconds, then fails. We also did a clear cry ipsec sa command and that does not fix it. We did some logging and it looks like it tries to build the VPN, then tears it down, then repeats the process over and over. We also removed and re-added the isakmp key to no avail. Any help is appreciated
Thanks.
Kamal Malhotra Tue, 02/13/2007 - 13:24
It will be difficult for anyone to suggest anything without looking at the config so I would appreciate if you send the config of both the devices so that we can look into it.
Kamal
nukeguzzle Tue, 02/13/2007 - 13:43
PIX 501:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname GreenbriarConst
domain-name comapny.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list acl_outside permit icmp any any echo
access-list acl_outside permit icmp any any echo-reply
access-list acl_outside permit icmp any any time-exceeded
access-list acl_outside permit icmp any any unreachable
access-list acl_outside permit icmp any any source-quench
access-list acl_outside permit udp any any eq isakmp
access-list acl_outside permit esp any any
access-list NONAT permit ip 192.168.51.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list NONAT permit ip 192.168.51.0 255.255.255.0 192.168.110.0 255.255.255.0
access-list 51 permit ip 192.168.51.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list 51 permit ip 192.168.51.0 255.255.255.0 192.168.110.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside "PIX 501 IP" 255.255.255.248
ip address inside 192.168.51.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list NONAT
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group acl_outside in interface outside
route outside 0.0.0.0 0.0.0.0 "Default Gateway" 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set f!stone esp-des esp-md5-hmac
crypto ipsec transform-set FSH3des esp-3des esp-md5-hmac
crypto map client-map 51 ipsec-isakmp
crypto map client-map 51 match address 51
crypto map client-map 51 set peer ASA IP
crypto map client-map 51 set transform-set FSH3des
crypto map client-map client configuration address initiate
crypto map client-map client configuration address respond
crypto map client-map interface outside
isakmp enable outside
isakmp key ******** address ASA IP netmask 255.255.255.255
isakmp identity address
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
isakmp policy 2 authentication pre-share
isakmp policy 2 encryption 3des
isakmp policy 2 hash md5
isakmp policy 2 group 2
isakmp policy 2 lifetime 86400
telnet 192.168.51.0 255.255.255.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd address 192.168.51.1-192.168.51.10 inside
dhcpd dns 192.168.100.249 192.168.100.227
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain company.com
dhcpd enable inside
terminal width 80
Cryptochecksum:xxx
nukeguzzle Tue, 02/13/2007 - 13:46
ASA(Config is too long to fit here, I'll post the parts necessary. All other sites are not having this same problem):
access-list NONAT extended permit ip 192.168.100.0 255.255.255.0 192.168.51.0 255.255.255.0
access-list NONAT extended permit ip 192.168.110.0 255.255.255.0 192.168.51.0 255.255.255.0
access-list 51 extended permit ip 192.168.100.0 255.255.255.0 192.168.51.0 255.255.255.0
access-list 51 extended permit ip 192.168.110.0 255.255.255.0 192.168.51.0 255.255.255.0
crypto map client-map 51 set peer "PIX 501 IP"
tunnel-group "PIX 501 IP" type ipsec-l2l
tunnel-group "PIX 501 IP ipsec-attributes
pre-shared-key *
Before hiding my external IP's I confirmed they were correct in all places. And since it does work sometimes, that shouldn't matter
