Is NM-2V and VIC-2FXO separate components?
Answered Question
Feb 13th, 2007
Hi, I have a C2610 routers running XM image and I am confused about this:
If I want to use voice ports on such routers, I understand I need to buy NM-2V and VIC-2FXO and VIC-2FXS. My question is, are the NM-2V and VIC-2FXO totally separate cards?
Correct Answer by gracianogardunojr about 9 years 7 months ago
my Bad I have a 2651xm not a 2610xm.You need to upgrade to a telco feature set like
c2600-telco-mz.124-12.bin
Overall Rating: 5 (1 ratings)
gracianogardunojr Tue, 02/13/2007 - 14:43
I have the same router here is what you need NM-HD-2V and VIC2-2FXO for your pots lines
and VIC4FXS/DID for analog devices faxes modems. The NM-HD-2V slides into the router
the FXO and FXS slide into the NM-HD-2V.
Hope this helps.
news2010a Tue, 02/13/2007 - 15:25
Correct me if I am wrong, does your image version also determines the NM and VIC version, isn't that right?
In my case I am running 12.3.16 Enterprise Basic. That's how I determined I should use the NM-2V and VIC-2FXO and VIC-2FXS.
Please let me know if what I am saying makes sense and if you don't mind confirm which image you are running. I was told that if you are using the VIC2- you would need a "T" train(?)
Also, please find attached my lab diagram showing what I am trying to do. Any suggestions on a better way to explore this, let me know. :-)
Marlon
Correct Answer
gracianogardunojr Tue, 02/13/2007 - 16:01
